  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
The stock BOV IS FREAKIN LOUD! And yeah with that setup it did idle properly, just need a bit of pressure buildup in the bov for some reason, dunno why, but yeah took it off because instead of getting ~450kms to a tank of petrol I was getting ~250kms, lots of backfiring and just ran really roughly and super hell rich, hence the high fuel consumption.
So put it all back, miss the PPPPSSSSSSSSSHHHHHHHHHHHHTTTTTTTTTTTT though :)
Why dont you buy a non-stock bov then?? :).... 250kms is rediculous!!
WA is full of dyno queens and ricers :)
i have seen more riced up hondas than on lygon street in vic
oh and it is really easy for mining jobs in particular at the moment.. got 5 openings for drivers.. close over 50k a year package with medical dental and super... shift work though and 12 hr days
Why because i want an exhaust first, ebc then maybe might think about atmo bov, might, love that sound though, really miss it, prolly get a pod first, then the sound of the stock bov will actually be hearable from either the pod or big zaust :)
Ummm when can I start? 50k WHOLY CRAP!
:Pres-hit:
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
