  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I don't know how to wind my boost down :( I can but it on a lower setting ut :D But what's the point in that!!
I'd really love to, honest! But yeah. Andrew said I could go, I just don't like going by myself that's all.
I haven't raced sinbad yet since he found a little bit of power. Last time I raced I didn't have the front mount I don't think :confused:
AVCR.
I had strict instructions when I got the car back from that being install that I was only allowed to touch the setting from A - B - off and that was it.
Those instructions were more for andrew so he didn't fiddle with it :(
Neil has shown me how to do it, I just don't like touching stuff incase it breaks other stuff. Stuff stuff? :D
