  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I don't know how to wind my boost down :( I can but it on a lower setting ut :D But what's the point in that!!
I'd really love to, honest! But yeah. Andrew said I could go, I just don't like going by myself that's all.
I haven't raced sinbad yet since he found a little bit of power. Last time I raced I didn't have the front mount I don't think :confused:
AVCR.
I had strict instructions when I got the car back from that being install that I was only allowed to touch the setting from A - B - off and that was it.
Those instructions were more for andrew so he didn't fiddle with it :(
Neil has shown me how to do it, I just don't like touching stuff incase it breaks other stuff. Stuff stuff? :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
