  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Just to inform you all, Team Shitbox is NOT anything to do with boostcruising at all.
It's a website that andrew has set up from scratch (learnt PHP) and it was his first ever attempt at making a webpage from the ground up. He decided we would get it hosted on the net for people who started team shitbox to participate in a forum.
*I* pay for this website and if any of you have any further derogatory comments to make about the website, it will result in a personal attack warning on who ever comments further. :rofl:
They aren't all shitboxes either. If you want to get pandantic with things, my skyline is part of "team shitbox" and so is Dave's cefiro, so is an 12sec WRX with the plates SHERIF that you may have seen around the traps, so is 16OTU which is an 11.3 sec Gemini who frequents the cruising scene.
why is it called "team shitbox" then :rofl:
wasnt there a crew of people that did actually have shitboxes out there? like $500 crappers.. or in fact like my r31 :rofl:
I'm glad you feel the love gordo. and Btw this has got to be by far the SADDEST converstion we have had on here in a very long time.
nah.. nowhere close.. remember that time when you stuck the gerbil down your pants when i dared you a lollypop and i distributed in kazzaa all over the internet? and you cried, and told your mummy.. and my mummy told your mummy she was a ****??
Wtf? are you serious? If we, as a group of car onwers cannot disscuss another group of car owners openly without you taking offence, then I don't think you should be moderating here...
I think it's shit.
In a box.
That races.
such fragile nerves on here.. i think its a bit poor if you can't openly just speak rubbish without somebody getting their knickers in a knot.
that borders on censorship.. and if we live in a sensored state we may as well go dig Saddam out of jail and make HIM a moderator.
easy....
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
