  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Just to inform you all, Team Shitbox is NOT anything to do with boostcruising at all.
It's a website that andrew has set up from scratch (learnt PHP) and it was his first ever attempt at making a webpage from the ground up. He decided we would get it hosted on the net for people who started team shitbox to participate in a forum.
*I* pay for this website and if any of you have any further derogatory comments to make about the website, it will result in a personal attack warning on who ever comments further. :rofl:
They aren't all shitboxes either. If you want to get pandantic with things, my skyline is part of "team shitbox" and so is Dave's cefiro, so is an 12sec WRX with the plates SHERIF that you may have seen around the traps, so is 16OTU which is an 11.3 sec Gemini who frequents the cruising scene.
why is it called "team shitbox" then :rofl:
wasnt there a crew of people that did actually have shitboxes out there? like $500 crappers.. or in fact like my r31 :rofl:
I'm glad you feel the love gordo. and Btw this has got to be by far the SADDEST converstion we have had on here in a very long time.
nah.. nowhere close.. remember that time when you stuck the gerbil down your pants when i dared you a lollypop and i distributed in kazzaa all over the internet? and you cried, and told your mummy.. and my mummy told your mummy she was a ****??
Wtf? are you serious? If we, as a group of car onwers cannot disscuss another group of car owners openly without you taking offence, then I don't think you should be moderating here...
I think it's shit.
In a box.
That races.
such fragile nerves on here.. i think its a bit poor if you can't openly just speak rubbish without somebody getting their knickers in a knot.
that borders on censorship.. and if we live in a sensored state we may as well go dig Saddam out of jail and make HIM a moderator.
easy....
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
