  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
was just wondering why society frowns upon the devotion of real anorexics, and in saying that I mean the ones with suficcient devotion to starve themselves thin, and yet society proclaims ad good and just the same sort of madness that it takes to be brilliant and churn out straight sevens at university. Was at a graduation ceremony for honours a while ago and the dux of the class had a gpa of 7 which means she didn't get anything but 7's for the whole degree.
In this day and age of obecity I think we should champion Anorexics with the devotion to stick with it, and frown upon the obece that lack the self discipline to get with the program.
thoughts chris.
Who says that the obese are no less driven than an anorexic?
I would assume that the same disorder that requires/allows you to absolutely destroy yourself would be applicable to a morbidly obese person too.
I don't think that your avaerage person is capable of the dedication that it would take to be corpulent to the same reverse degree.
Any excessiveness is frowned upon by society for good reason, whether it is anorexia, obesity, workaholism, greed, etc, etc.
Different sides of the same coin.
This person who had a high GPA across the board, is there any moderation in this persons life or did they devote everything they had to atttaining those marks?
Sure good marks would indicate a successful future, but against what measure? High paying job but no life outside that job (i.e die alone but rich).
Moderation is the key, but it is so easy to lose sight of.
1. The obece are not driven. Often obecity comes out of a sedentary lifestyle and lazyness more than anythine else. Also the undereducated are far more likely to be obece than the well educated and more fortunate. It tends to be a dizease of the lower calsses and the less socioeconomically endowed groups of society but times they are a changing and that no longer rings true.
2. Thus these people are the ones with devotion. We should really take them around to schools as motivational speakers
3. excessiveness in terms of finding a solution to a problem or artwork tends to be champpioned. Many of the great artists and poets of the world were mentally unwell and yet we appreciate their work.
yes granted everything has a price.
I think another point is how society can turn a blind eye to its set of double standards and the question of how our value system became so skewed. Once again we are brought back to the question of intent and the idea of doing all the right things for all the wrong reasons.
don't know if you'll read this but thanks for the effort in your response.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
