  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
morning everyone. (who still comes here) :wavey:
-Who the hell are these losers who post on message boards? Holy God I've never seen a more depressing lot of prepubescent nerds in my life. What sort of existence have you carved for yourself when the highlight of your day is writing a 3-page flame on why Squizz-Wang is better than Squizz-Wang 3D and then hitting the refresh button every four seconds for the next hour to see if anyone replies?
