  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
10.5° at soccer training :)
Sh*t!! We had it down to 9.5 on the car aircon but that may have been because of the..."wind factor" incurred from such speed, lol we didnt want to stop until we could get it into single digits.
