hmmmm
always problems when chasing power in my experience
the amount of crap I had to put up with in the S13 to get it to 225rwkw you wouldn't want to hear.
And after I sold it the guy who bought it wrote it off after four weeks, I was so upset for some reason :D
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah they get pretty hot, im still 'testing' i guess. i might move them if its a problem. gav seemed to think it was ok tho so i think they'll stay that way. i've actually cleaned up the hoses a bit too - hidden them (if thats possible)
i see you're bidding for a powerfc.. watch those second hand ones! i got burt a little. the hc was rooted but he gave me back 200 for it. and the ecu is an older version rom and doesnt do data logging thus the tune method gav is using.
Yeah just an EOI at this time.
More than likely get a new one from Nengun for $1100 with hand controller.
If the guy goes as low as I want, we will see :D
T & T sounds sweet. i guess im ready! cept tyres but i'll just let mine down a bit.
Yeah I was so close to a thirteen last week, except for the bald tyres.
I borrowed Jay's tyre pressure guage and thought I had let them down to 25 PSI, when I went to the servo to fill them up one was on 33psi and the other was on 31psi, so his guage wasn't quite accurate lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
