  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Gordo, come clean about your plans for the t78 powered soarer VIP style project....
that is the chaser :thumbsup:.. not now though.. cost too much in the end to get it the way i'd want it..
RMA imports - now would u recommend them? I am also considering directimported?
I don't want to be stuffed around, i just want another car ASAP..
any other suggestions?
I know the guy that runs RMA... If u want I can PM you his name and contact details?
And yes I would recomend them, if u had seen Ray's GTR you would have died. It was a 1996 with 24,000 genuine k's... John was going to buy it but it sold it 2 days :thumbsup: He brings in very clean cars and is in Japan every month...
Also my importer I used is very good, Bruce's partner goes over every few weeks to Japan as well to work with the contacts.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
