  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
what squeaking noises cyrus? howd ya fix it? how you doin?
Hey ross, I'm doing great!
After we fitted James™ exhaust we heard a squaking noise, turned out to be a faulty belt which Gav replaced free of charge, as he was the one who fitted it for me :)
Had a GREAT day, firstly did tax and found out how much the government owes me, then spent the rest of the day playing round in several parks close to gavs while the belt was being replaced then drove down to the spit to let the kids wear themselfs out there now am home!
Sorry Chris, was going to stop in along the way but Blake (my son) had gone to sleep so needed to get him home to bed ;) means he'll get up in 3 hours hungry as hell! Then he wont want to go to bed till like 1am :( oh well the joys of parenthood! :(
thats awesome cyrus :D
chris: what i meant was the paper label in the 50tub, but the discs are blank white on the back. the real princos actually have a smooth back with heaps of shit written on them, im pretty sure.... ??
Got some in my hand right now....they are smooth and have princo and write speeds and other info printed on them.
Where did you get the other ones from?
the disc shop. my boss has a close affiliation with them for some reason, and he buys our machines for work from there. they are the biggest heaps of shit, and way overprices. my monitor has all the pixels compressed down the left, the cd-rw/dvd-rom wont burn, and the hard drives are ata100 and it cant multitash, eventho it a 3.0HT. i hate it.
oh well
a fool and his money.....as the saying goes :D
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
