  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey ross, from your sig, where is Tripikarta?
Yeah I always used to race cause I knew I would lose, but now, I know I could prolly smoke em :)
BUT to race during the day is utter stupidity, i mean there is TRAFFIC for one!
coolish. bit o rain today for the first time in ages. hate driving in rain. went and visited my mum today, 350km drive all up there and back. car went really well, first long drive with the powerfc and cam gear. actually got better economy than the standard ecu. very surprised.
