  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
****ing make me go down stairs too take it off to get a clear pic.
Now die.
LMAO Like you would have bothered to take it off, to take a photo! Your far to lazy.....pop bonnet and prove stock bov or remain silent!
