  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Only problem with having such a stong coffee is that when you come down it is like being hit by a tonne of bricks, but that is easily fixed with another cup TWICE AS STRONG!!!! MAMaMaMAMAaU au ua ua hhHAh H h H AH aHaHah hH AhaHHA ha h aH aH h HA aaaa!
Hey Charly, Hey dude I was thinking last night, just get your work to hire me and we can do tag team pyscotic sarcastic paranoidally delusional brought on by super strong cups of coffee type personal remarks at the other office staff on Friday's! :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
