  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cyrus how did you manage 6 hours to install a boost gauge....??? What the hell were you doing, is that including a 5 hour lunch break or wat :cheers:....
Nope can you say NOOB!
Ah my little kiddies. how are we all
Meh work sux0rz!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
