  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I know how you feel :D
I just wrote an email to adrian saying it's been a ****ed day and I wanna go home!
:grouphug:
Yeah id complain to my boss but he doesnt care ..... so i complain to Simon haha We just sending whinging emails back n forth haha
