Hey glenn,
Unfortunately fulcrum couldnt put me in till a week after the cruise :)
So ill be running wounded, but runnings thats for sure :D
Cars running good with new oil, would want to, its like the best oil you can buy.
No boost controller either, took shitty bleed valve off in preperation for the AVCR. So shes running a lowly 6-7pound at the moment.
Fronts missing the intercooler too, which will be on its way soon, cant wait !
man... you sound like you got lotsa plans for your car.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hmm to be honest i havent heard much of that album, although radioheads style is meant to be like that i guess
I think just about any music has a tendancy to either make you sad'er if you are sad, or make you happy'er if you are happy
If you know what i mean
Coldplays good to listen to if your down, there like the new age oasis but better and this time minus the shitload of drugs
yeah dogs look so funny when they're having nightmares. :D
he woke me up once!!... kicking in his sleeping... and i was like WTF??... then he woke up staring @ me with big opened eyes...
he could have eaten me alive then :)
Yeh i got heaps planns for the car, been saving and saving so now i can just go BANG!
Pretty much got everything already, just need intercooler, catch can and CES split dump pipe.. already got 3" straight but want the split
then i chuck the sitc, avcr and safc2 (piggyback heaven hehe) in and get it tuned.
Yeah, I must concede that mainstream rock is one of my real weaknesses. I know it sucks But I ust can't help listening to it. Also I still am a bit of an oasis fan, even if no one else is. It's kind of why I like bands like Everclear. Bands that stopped being cool sometime in the mid ninteys but still kept making music.
Actually one album that has grown on me is Fallen from evanescance if you take the time to listen to the lyrics, mush of the album is quite an eloquent F**K you.
i missed Oasis.... both the brothers rocked.
yeah, I olved those guys when they were in the press a little more, Like someone would ask for a signature and they would go the punch out, Someone would take a picture, and thy would go the punch out. They were so rock, and noel, or was it the other one is married to one of the Appleton (sic) sisters. And Noel had a rocking mullet, it wasn't quite all business at the front, but it was ALL party at the back.
you have a very colourful and expressive signature knore. :)
Thanks
Lets just say i like my specialised movies
I own a limited press (200 made) copy of Fear and loathing in las vegas
I love the movie, such a out-there/off the tracks film. Its a classic.
Oh and scarface.. well what do you want me to say ?
hehe
sounds like you and Warwick on a bad day actually :)
Guest
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
