  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Charly.. the car of course... The lil nagging problem I had wif the HICAS light and the rattling noises is become all too frequent and its damn annoying..
Just got a call from my mechanic, he's organising a data stream to see what exactly is wrong..  HICAS sensors apparently is not covered under my warranty.. but ABS is ... grrr.. not happy at all..
Hrmm.. guess the bright side is that a friend of mine is going to help me get some insulation into the doors and also fix the creaking that I have had on the passenger door for a while.
Whats wrong with your car dude? :D
Nexus.. I heard something about his wife taking over 75% of everything he owns and the shop was shut ?  I might have got it all wrong... thats why I wanted to see if you guys/grls know anything about it. :)
I THINK THAT MY PERSONAL LIFE HAS NOTHING TO DO WITH YOU OK
THE INFO YOU HAVE HEARD IS BULLSHIT.
SO SHUT YOUR MOUTH PLEASE - OR MY SOLICITOR MIGHT DO IT FOR YOU.
Yeah...  She may just come in here and set the story straight :headspin:
NO I WILL THANKYOU
GAVIN WOOD AUTO TECH IS NOT CLOSING DOWN AND NEVER WILL OK
I AM BUILDING THE BUSINESS TO GIVE TO MY 2 BOYS WHEN THEY GROW UP
THEY ARE ALREADY FOLLOWING DADS FOOTSTEPS WITH REGARD TO
MOTOR RACING
IF ANYONE HAS ANY QUERIES OR DOUBTS - PLEASE DONT HESITATE
TO CONTACT ME ON 0417760278
I WILL BE MORE THAN HAPPY TO SET THE STORY STRAIGHT
IT SEEMS TO ME THAT A LOT OF PEOPLE ON THIS SITE HAVE NOTHING BETTER
TO DO THAN BAG SOMEONE ELSES LIFE - THAT TO ME IS VERY SAD
GET A LIFE PEOPLE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
GAVIN WOOD.
Not at work, the time over on the island was awesome, had a great time, but too much exercise for me, did more exercise in the last 3 days than I have in the last 3 years, so still a bit stiff and sore, got a raging head cold which is why I decided to call in sick :D
i think somebody wanted to set some rumours straight.. fair enough i guess..
Please PM WTF that was all about plz?
Guest
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
