Good to hear Chris,Roys a top bloke and he helped me out heaps :D
Where the power wire branches out it's right under the throttle body.
I will also put up my maps maybe even tonight or on the weekend.
One thing I learnt yesterday is check your plenum bolts coz I had one missing and god knows for how long.I put another bolt in and now it spools up so quick like 500rpm quick.I would get 11psi at 4000rpm in second before and now get 11psi at 3500rpm,so much better to drive.
  • Replies 121
Well, on saturday morning ( I had a few hours to kill before going to a wedding LOL!) I had a look at my spare motor to see if I could locate the power wire going to the injectors
As it was a spare, it was all done for a bit of practice, next weekend hopefully I can get it all done
Took me about half a hour to get everything off and I found the wire no probs. On mine I traced it from the injectors back up the loom, and it branced off into four, with one wire going down and branching of to three to feed the foward 3 injectors
I tested my resistor pack, and it measured 6 ohms on each wire, so looks to be good.
How did you guys get the plugs of the injectors? Being a spare motor I tried a few things and the only way I could get them of was by pulling that retaing spring wire thing off but I kept on breaking the little plastic bits off that held that spring in place!! Hopefully there is a better way than what I was doing!
All seemed pretty straight forward though, to get the fuel rail out I had to pull the back two injectors out of the rail, as they would foul on a hose going to the plenum
Another thing, after taking the throttle body and the AAC valve assembly off the gaskets where buggerd, chances are it will happen when I do it to the motor in the car it will tear them too, can I use gasket paper and make some replacemnets up or are gaskets available from Nissan as a spare part?
Other than that, all seems to be not to hard at all
How do my maps I have compare to everyone elses?
Chris
i used a pair of needle nose pliers to remove the injector plug clips...they came off with no hassles...
I replaced my throttle body gasket and aac valve gasket on mine (i had every gasket replaced on my new motor etc.) as every one of em is at least 12 years old....go the Nissan genuine 'cos their cheap, and not worth replacing later if they leak :rofl:
Sorry, worked Saturday, and slept most of Sunady after the drive back to Vic. Ill have a look at the Maps later this week and post up before sat morning, though my map will only be good for up to 2500rpm then our turbo characteristics are likely to be very different
No probs mate, I have ordered my gaskets for the throttle body and AAC valve, they should be in today
I have a feeling that my map is for bigger injectors but I will wait to do a quick comparison first. If you guys don't want to post them up you can PM them to me if you want
When I get my car tuned I will post up the final map for comparison's sake. I punched in all the numbers into a Excel spreadsheet BOOSTD made up, it all looks to be pretty good, with no big holes or dips in the fuel map
Is there a option in the PowerFC to adjust the injector scaling? What I was thinking is if the tune is no good in my car to get me around for a few days before I get it tuned, I could always load the standard map and reduce the overall fuel map by 63% (280 v 440cc injectors, please correct me if I am wrong??) and it should be drivable at least, allthough it wouldn't be seeing any sort of boost before it hits the dyno!!
Chris
Roy has a PowerFC
Got all my gaskets and crap just then, so looks like this weekend I should get it all done. Also picked up a boost control kit for the PFC as well :D
Just need to find out if my maps are suitable now or if they are no good, if not I will do as I said in my previous post and default the PFC and use the injector scaling function to drop back the amount of fuel, either way it should work............
Chris
Ah ok, thanx. I just read the whole post and there was a post from him from Feb saying he's using rb20 ECU. Must've upgraded since then. Would RB26 injectors work on the RB20 ECU or does it need to be re-mapped?
It would need to be re-mapped, as they are a much larger flowing injector
Hey Chris,
this might be a stupid question, what does the pfc value represent, is it load?? or am i confused???
Also on the fuel map, is 136 the largest number u can go (most amount of flow?). This would have to be changed when larger injectors are fitted or is that where injector correction comes into it?
I'm trying to understand how these things work.
Cheers
Hey Chris,
Cheers
As far as I can work out - the PFC Value part is refering to the location of the point of the map, from 1-20, so I am pretty sure its load. I didn't come up with the chart, so I cannot be sure, I just punched in my numbers I had copied of my PFC
136 isn't the biggest number you can go, but I am not sure what it goes up to as I haven't played around with it much. The map that was in there before mine was from BOOSTD's R33, which was running standard injectors and had numbers well over 1000 entered in, but I will add that the fuel map looks pretty average to me, but I am no expert
I am trying to find a english manual so I can work out all the functions in the hand controller
Chris
Chris
Looking forward to seeing this result... just went and got me a set of gtr injectors :D
I am going to be taking alot of pictures so in the future if someone wants to do the same it will be pretty straight forward
Don't forget to get the resistor pack!
Chris
so is it right to say that your tune is more for response compared to boostd which was more for top end???? This is what i'm gathering from comparing the two or its not a fair comparison (rb20 vs rb25)????
This is pretty interesting!!
I have no idea whats mines tuned for, I plugged it in, it started, I turned it off.
I copied the maps from it and that was it, my car is currently running on the stock (chipped) ecu
It will be interesting to compare it with what Roy and R31POWER's maps are like, especially the differant fuel maps
Chris
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
