Yeah I'll reset it tonight and see what difference that makes, to be fair I have played with quite a few settings :)
To be honest, I'd expect that even "crappy" kit lenses should smash a basic point and shooter without needing to be a pro photographer to make it so.
We'll see what resetting the settings does. I might also do some testing with the 55-200
  • Replies 64
to be honest, i dont see a problem with those shots. The problem might be the picture you see isn't what you were trying to capture, or your expectations from the camera in auto mode.
There's more settings, more options, more information. It's kinda like the difference between describing something to someone who knows nothing, or describing it to an expert.
Like explaining a car to your girlfriend (Point and shoot) It's a red car and it's new.
'cool'
Or to an expert it's a red car and it's news
'what make model?'
what year?
what mods?
power output?
RWD?
blah blah
you need to fill in more blanks to paint a richer picture or tell a more detailed story.
Yeah I get what you're saying.
Am I the only one who thinks that on "actual size" the engine bay of the car doesn't look that clear or that the pictures of the book look a little soft around the edges? Surely that's not being too picky?
I guess I was under the impression that given the camera has a much wider ange of settings to choose from it would be smart enough to outdo a point and shoot on auto in most situations.
By actual size you mean when zoomed into 1:1? I'll be amazed if you can find any kit lens (or any P&S) that can produce sharp clear pics at 1:1 crop
Yes it can - maybe do exactly what you said - do some side by side auto tests (making sure settings are reset) - then go from there
OR if you care that much you could always do something crazy like getting a good lens for $137
then you can do some side by side comparisons at 50mm between the 50mm lens and the 18-55mm kit lens :)
The dog and car shot were daytime and well lit, the book shot was around 6pm but under the pergola.
I've found that without the flash It's almost impossible to get a good shot in low lit indoor scenarios so far, I wasn't overly impressed by the fill of the flash either, and by fill I mean how deep into the photo it can light up. (Trying to take photos of someone doing a speech from a respectable distance for example)
But we'll get to that :)
Your file download should start immediately.
If it does not start automatically, please click here to start the download process.
man just host pics with photobucket and copy IMG tags in here.
i actually prefer file hosting over image sharing, at least they don't fuck with your photo and ruin the metadata etc.
No idea about flickr as I dont use it.. But never had a problem with photobucket ever.
Dan - just open up image in lightroom or photoshop. Resize to 1024 max width or height.. then apply slight sharpen and save as srgb jpeg.
Perhaps your uploading rgb format images. If thats the case then colours will look off. srgb is best view on web browsers.
Then upload to photobucket (which is free). Then just copy the IMG tag link in here. Saves people clicking on links and downloading each image.
my 2 cents.
Edit: how is flickr altering your image? As in what happens?? Millions of people use flickr so doubt it is.
Edited by siddr20
Happy to do that next time, but I'm not about to go back and do it for these ones unless the consensus is it's killing people horribly to click the current links lol
there's that laziness coming out..
