Bonnet Hinges - $20
Rear window wiper motor - $30
Fuse box area aircon vent - $60
A/C Condensor Fan - $50
Centre console "tunnel" type thing at rear of radio to floor? - $45
Aircon Temp Sensor - $20
Boost sensor - $15
Side Repeator lights ( Orange - Amber ) $20ea or $30 both
Pedals Accelerator, Clutch, Brake with all brackets $100 for the set "GTR" rubber in good cond.
Odometer Cable - $20
Air Con Control (DIN size unit under radio) - $80
Std. Exhaust Manifolds - $70
Exhaust temp sensor - $20
HKS "Mushroom" Filter kit fits to std. AFMS - $70
ATTESSA oil Res. - $30
more to come msg me on 0422 648 745 prices neg. message me with listed price and your offer.
Buyer pays for postage if Aplicable.
-Daniel
https://www.sau.com.au/forums/topic/343469-r32-gtr-odds-and-sods/
RB26DETT Valve caps - $40
Thermostat housing $30 and other side casting for radiator $30 also
Seat belts $200 set or $60ea
Std. RB26DETT ignition Coils $100
Pwr Steering Fluid Res. W/ Lid and wiring - $50
Charcoal Canister (Transaction Aus Carbon) -$40
Coolant Res. - $50
Winscreen washer res W/Pumps - $70
Some Std. FMIC piping $40 Lot
Wiring loom (Cabin Fusebox loom) W/fuse box and all fuses/relays - $150
"Twin Turbo" Pipe RB26DETT - $80
ABS Unit $200
Aircon Vent (Centre Dbl. vent) $70
Fuel Cap Cover W/ hinge (Gun metal Grey) $20
Starter Motor - $40
Bonnet Release Cable - $20
Tail Lights - $70 ea
Boot lid Rubber Seal - $40
Engine Mounts L + R $40 ea
Passenger side reverse light - $40
Cam Position Sensor - $50
Std. Cam Gears - $30 Pair
Std RB26dett Cams $180
Fuel Rail - $60
A/C Condensor - $50
Pwr steering fluid cooler - $30
Flywheel - $100
RB26DETT Sump and diff $180
Steering column W/ Ign Barrel + Keys - $300
Engine Crossmember - $150
Steering Rack + lines - $100
RB26DETT Head Studs - $60
Accel. cable - $20
Passengers A pillar - $30
Clutch Fan - $40
Boot Hinge + Springs - $60
Front Sway Bar Std. - $60
Passenger Steering bar thing from rack to hub - $20
Air Comp. - $60
Passenger Door (Red / Burgundy) W/Window, no card or handle $200
Drivers door (Gun metal Grey) Wwindow, no card - $210
RB26DETT Cylinder Head 1 piston gave up and shattered so 1 cylinder has mashed valves and rough suface may be repairable -$40 pickup only
RB26DETT Block (1 missing piston, Bent rod, and has bashed through that sleeve) 5 pistons left with rods, Crank and large pulley part open to offers
Throttle Position Sensor - $40
Injector wiring loom cover (Black plastic) - $20
Rb26dett dip stick - $10
Centre Light (Roof) $20
Dash Cluster - 180kms model, $100
Dash Surround, with all switches gd cond no cracks $100
BUMP! please read through carefully, AM WILLING TO CUT PRICES BY A FAIR BIT! message me an offer need to get rid of all this soon too much clutter
Edited by SSSLOW
Adrian P - Should still have them haha any idea how to go about getting them out?
Das Kamu - Sorry about inbox, i have just deleted a load now, yes I do have the LH seatbelt PM me if your still interested and a price?
  • 2 months later...
Hey - do you have the drivers side or passenger seat belt clip ?
Will buy the whole drivers side seat belt and clip $60 if thats the deal...
- posted to ACT.
Edited by Sinista32
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
