Yeah I'm not a fan of the lights up high, get rid of them and combine them in
the headlights. I think originally its a soft roader kind of thing, looks
horrible in standard form but slammed it looks awesome!
Wheels are TE37s I think.
The doors are kinda sweet, esp the way the rear doors open. Really means can get stuff in and out of that car.
Very transformeresque. Just needs a few tweaks to make it less OMG.... The Juke was kinda hawt.
Id rather nissan juke
this could be a pretty good little sports run around...
i reckon drop the indicators down where the little foggies are, and then have fibreglass inserts where the original bug eyed indicators would be...
either smooth them off, or french some "air intakes" into the inserts...
Edited by dazman
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
