Danooh- I will certainly let you know and congratulations on your car...
I didn't hear any noises but it did misfire between 5K and 6K rpm's.  I picked up the car and it was completely out of fuel.  I filled it to the top with BP premium.  I drove it for a good 60km's before I had the problem.
how 'big' was the misfire? was it a hesitation/cough, or more of a backfire? check your fuel filter - could be as simple as a blockage.
was the car pulling hard before it happened? I haven't revved my car over 3000rpm (free rev) as I want to go right over it.
I bought it redline engine and gearbox oil the other day - so will be changing that before I actually take the car on the road. My car ran out of fuel on in my drive after we took it off the back of the truck - I will changing the fuel filter as well.
hopefully it is more of a minor thing with your car
damn another perthian, and even better, A CHICK!!!!
ummm if it was blue - your rings are well and truly buggered
if it was black - your running really really rich
if it doesnt want to start, then your probably gonna find either a piston's jammed and/or a conrod is jammed also
either way, your gonna be up for big bucks for some1 to look at it
Skyline Performance Imports haven't had a chance to look at it yet.
One other thing that I can recall is that when I turn the car over I noticed that the oil pressure light was on.
There was no backfiring it was just misfiring.
OK
It has been confirmed that the car requires a full engine rebuild (around $8K) :D
I was unknowingly driving the car on full boost (close to 30psi) which resulted in the damaging of the rings and pistons. A very very expensive lesson to have to learn...
One of the problems with buying a modified car... you don't know what the guy before you has done... Mmmm 2 bar boost... I don't think that even if you had changed it back to ~12-15 whatever standard GTR boost is that you could have saved that engine... the guy who sold it in japan obviously knew it was on the way out (which sucks for you) and i just hope the same won't happen to me when i get my 93 GTS-t.
welcome to the rebuild club! they took my engine out .... apparently i broke 5 pistons :D Hope you have a very generous bank manager ...... but its a lot of fun once you get it back .... go the forgies!!
Pilot boy .... never seen you around before! hello.
I reckon its probably because the car has been sitting for so long, take it for a bit of a drive clean it out, but dont rev too much just incase.
I hade the same problem once, my car been sitting for about 4 months, started to drive it and heaps of smoke came out, after about 1k it went away.
ben
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
