Fs: Red 1996 S1 N15 Sss Pulsar
Yes your correct haha I found that the passenger side wire was cut from previous owner when it was stripped for a re spray, I now have all blinkers except for both front bar blinkers, both bulb holders have continuity but don’t illuminate, this is the same when hazards are on, I assume I may be missing an earth
Just a budget thing I'm sure. Super tourers didn't make it locally and the drivers in that car were paying for drives; so the business case doesn't stack up unless the base car is cheap
I rewatched some video tutorials of other people doing it, and compared it to mine, I think I might be mixing it faster than the other guys. @GTSBoy when you said aggressively I guess this falls under that. The level of hardener seems consistent, I'll experiment with it more and report back.
@silviaz first thought is you are folding air into the filler as your mixing the hardener through it, GTS beat me to that. Next thought is, maybe too much hardener was used. Unfortunately there are a lot of variables that can give you pinholes. Maybe consider weighing out the filler/hardener to remove this variable.
