I'm getting a genuine US made hi flow and paying the extra $100 for it ober the universal (total cost $450 fitted)
I find things like this quite amusing :)
We all seem to think that things manufactured overseas has to be better than locally produced products, and for many things, that's absolutely true. But for things like cat convertors, which are made by machine and no hand welding, they're just fine.
Think about this. Over in America, there are people bragging about their "Australian-made, Laser-Cut Redback Catalytic Convertor"... :wave:
Magnaflow are US-made
Catco are US-made
Davico are US-made
Eastern are US-made
Walker are US-made
Arvin are US-made
Redback are Aussie-made
So as you can see, pretty much all the cat convertors sold here are US-made anyway...
https://www.sau.com.au/forums/topic/34369-cat-size/page/2/#findComment-691722
Guys, just reading your thred,I fit exhaust for a living and if you knock the guts out of a cat it is the best way of making your car sound like a shitty 253 kingswood. Although they flow well the gutted chamber becomes a resinating peace of crap.Just fork out and buy the cat should cost no more than $300 fitted.If in dought about power loss do a back to back dyno on straight pipe v's high flow cat you will be surprised!
https://www.sau.com.au/forums/topic/34369-cat-size/page/2/#findComment-692354
A non turbo would sound cr@p but turbos sound mint, better flow for free a cant see a loss :aroused:
https://www.sau.com.au/forums/topic/34369-cat-size/page/2/#findComment-692740
Tried to get my new exhaust fitted today, its a Veilside 3.5" system with no cat, just the front pipes, two small resonaters then muffler, but the exhaust shop wouldnt go for it, doh!
Theyre reasoning was it would belch flames out the back (they wernt concerned about epa) but they wouldnt listen to me when I said it already belches flames out the back :rolleyes:
LOL flames are sick :wassup:
personaly i would buy a 3'' System and fit it myself. a 3'' pipe is a 3" pipe it doesnt matter what brand it is, just get good aluminum and somthing that looks good in the way of welds and bends, you'd pay harf as much and get good satisfaction.
my 2 cents :(
https://www.sau.com.au/forums/topic/34369-cat-size/page/2/#findComment-692743
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
