  • Replies 48
well i use the trapster poi on a tom tom running on a htc diamond.
it won't tell you about mobile police and mobile camera's but has the most up to date poi list.
on that phone i used trapster app and in 2 hours it amounted to about $350 usage.
tested it on my iphone4 which has a 500mb plan used about 70%.
I'm suprised everyone elses is using such little data whilst roaming.
there's clearly something going on with that app and my phones which is out of the ordinary.
not 100% certain but i remember some form of review for a bentley continental gt.
I think they come with radar detectors. so basically what can the cops do there as its factory fitted.
Edited by rotarytt
make you have it pulled out of the car. just because something comes from the factory with something illegal doesn't magically make it legal.
as for your data usage, that is exceptionally high. it may come down to the fact that it is a windows OS phone (pretty sure it is anyway), and the way that it uses the mapping (and how zoomed in you had it). but on android phones it isn't bad at all.
My Pro78 has saved me from handhelds, incar, multinovas and lidar (even have a video of it picking up the lidar from 185m away).
I have 16 driving infringements and 3 charges on my driving record (according to the cops that put the yellow sticker on my 32 :thumbsup:) but in the last 3 years since I got my RD, I haven't had any.. I'm actually back up to a full license now. They do work.
Edited by bubba
I have 16 driving infringements and 3 charges on my driving record (according to the cops that put the yellow sticker on my 32 :thumbsup: ) but in the last 3 years since I got my RD, I haven't had any.. I'm actually back up to a full license now. They do work.
hey would love to see the vid, is it online? thought once the lidar hit you that was it, no time to slow down. im intrigued, i have one less infringement than you and want to keep it that way ;) somehow almost back up to full points now and nothing in last 2 yrs (all were with Audi weirdly nothing since i got the R33).
mostly its been from smarter 'when and where to give it a squirt' thinking but would love something like that for the unexpected. emmachizzit?
Jammers are designed to give you some more warning time, they jam the signal for a couple of seconds while throwing you an alert so you can get back down to speed, then it turns off so the cops can get a clean reading.
being from the USA but immigrating to oz , I have used a lot of radar/laser equipment and even know how to build/repair it
in USA
successfully jammed a KA band radar at damn near pointblank range while exceeding the limit by at least 30mph
and lidar at over 130mph in a 80 zone, in my stupid days of NFS RX7
(lived in montana which had no speed limit during the day at the time I lived there)
fact
you can jam laser and radar. including lidar. which was made two blocks from my house in usa. little bastards.
fact
it works but cost a bundle in oz to recreate, thousands !!
fact
not legal to jam it, if caught they will hang you !! and flatten your car
fact
not worth it unless you drive in the open outback areas at extreme speed, you will be caught if your the first car hit with it. and the above applies then
per the request they do sell legal Radar/safety camera which can be used in all states, since they have a off switch for the radar portion. it is undetectable !! if hidden well. which cost money to install, not a 5 min job. more like a few days worth
Bel and Valentine are some good ones but you can create your own jamming equipment, and no don't ask me too. I wouldn't do it for anyone !!!
I think OZ is over the top with revenue producing devices, and very nanny like. but the drivers don't drive in snow or ice, so the skills aren't the same
plus OZ cars have a lot more power then the average US cars.
really bad drivers and speed is a bad idea.
teach drivers to control cars is a better idea then a friggan log book and P' plates
hope this is bit more unbiased , I'm looking at one for my car but they cost a butt load here
and the iphone app is really not that great, I have it, dont even bother, just don't speed thru cameras
Edited by sapphiregraphics
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
