nicenice. Never really understood the difference between satin and matte. My friends w/shop is bringing in the new matte clear, which was designed for the new lambo colour range. Was thinking of using this, but still kinda undecided
  • 1 month later...
satin is about halfway between matte and gloss...still no reflection but a much "smoother" more refined look...matte is more rough and backyard looking
i had my rims sprayed matt black before i decided to paint them lambrghini satin black..... best decision i ever made. i think matt is ugly and its never done properly either....definately go the satin bro..
Hey bud, i think you should go for it, given i am somewhat biased, its a great look whether you go satin or matte, which ever way you go not everyone will like it but no doubt you're modding the car to suit you and not everyone else.
I like the non-gloss look; it's akin to the 'rat-rod' look that is popular in he US at prsent. the rat-rod look gets away from the flashy,chromey approach; by using 'flat' paints etc; the peformance aspects of modding remain...pretty cool I reckon.
here you go.. im sure there are other photos of this floating around the net, i first saw flicks of it a couple years ago
satin black looks a heap better than just flat black too -- usually satin looks like it was done properly, and flat black just looks like you did it with $2 tins of spray paint even if done correctly..
Edited by ohno1
Id agree with that..
Thing is, i'm betting many people won't dig it.. and although most of the time you don't modify a car with regards to resale value i think painting it flat/satin black will have a big impact on resale (ability not just price!)
Yeah I don't care. I won't sell mine anyway.
I'm in the middle of a proper PPG jet black/ deltron lamborghini and mercedes approved matte clear respray, and I think it looks great. Lots of people told me I was an idiot, but even the painter, who was against it originally, says it's growing on him each time he sees it.
I would love to add pics as part of a build-up thread on here, but I'm fairly computer illiterate and don't know how to re-size the 5mb+ pics my DSLR takes. Anyone?
  • 1 month later...
I know theres something you can dl off the next which does it for you. Try google image resizer. Im dying to see these pics
  • 4 weeks later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
