good to see them on the car Drew
what is the quality of the paint etc like irl? im really skeptical about these US brands and thats my main concern
i thought you ordered the matt bronze?
im still a good 1-2 months away from recieving mine i rekon
also did you weigh them?
i did some figures and looks like ill be around 4lbs lighter per corner, but will only know for sure when i put the tyres on
Edited by domino_z
Thanks for comments, yes I quite like them.
Domino: The quality is very good, nothing wrong with them (which is expected)
Yep, these are the matt bronze with gun metal lip. I saw a picture that a supplier took just after I ordered and it made them look glittery and much lighter.
In real life they look more like the AVD photo shoot pics.
I did weight them (with tyres)
front: 28.42KG
rear: 29.9KG (stock 30.3)
I am suprised to see that the rear advs are actually lighter in stock.. Especially since the advs are 21's !
The stock run flats must be heavy.
To be honest, now that I am more interested in track work I wish I saved the money and got some carbon parts.. Or used new slicks for the next 5 years.
if those are matt bronze i need to sort my order asap
those look flat grey to me
i was expecting the matt bronze to look like this
http://www.adv1wheels.com/adv1wheels/galle...san_GTR_5_2.php
adv10_automotive_connoisseur_execstudio_adv1_wheels_advanceone_deep_concave_nissan_gt-r_r35_black_bronze_gunmetal_07.jpg
re tyres yep, its the tyres that are the killer with the oem setup. im saving 7lbs a corner on tyres alone going to 21" yoki advans
Edited by domino_z
When photo is taken with flash the look a bot more like the above wheels.. But just looking at them they appear much darker and grey/brown looking.
thanks for that drew
ive requested additional pics from ADV
in for more pics of your setup too to better gauge the colour
I love these wheels. Looking forward to see them in the flesh.
This picture is in the sun:
This is in shade:
I have lowered the car about a half inch more than before.. So its probably 2 inch lower than stock now.
To be honest, I dont think any wheels with dish look good at stock ride height. If your not going to lower it you wont find a better looking wheel than stock.
Also, if I could go back in time I would have matt black centre and gloss black lip.
I have couple more pics on my blog too.
Edited by druzilla32
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
