Well my fuel pump died last night. Luckily it just died as I was parking. I went to put the stock one back in, it makes a horrible grinding sound. Got it towed home for free in the end. Trying to get pump out so can get another one monday, and hopefully put it in - and not pay for another towing, and to get somewhere like trojan to do the whole job.
Where do I get a new fuel pump, what should I get and what is it gonna cost me?
Additionally, I can't actually work out how to get the fuel pump out. As in that tight black pastic ring that holds it on. Still to try to pull the rubber hoses off, but losened the hose clamps. Any one able to provide some help and advice.
Additionally, my tire well was full of water, thats always fun *sighs* I'll have to work that problem out also.
https://www.sau.com.au/forums/topic/344208-the-problems-begin/
  • Replies 41
I got a walbro one from trojan. didn't cost too much and they swear by them.
put it in yourself, just unscrew that plastic thing you're talking about by using a long screwdriver on the ribs on the side of the cap and hit the screwdriver to get the thing spinning.
the walbro pump is basically a straight replacement, might need a tiny bit of fuel hose and a hoseclamp to make sure it doesn't ever come off it's braket...
it's either that or get a bosch 040 intank pump. Which requires a tiny bit more work to mount... either way not a big job.
The tyre well - was it the issue I mentioned previously last time you said something about it? Big phat hole in the bottom that's supposed to be plugged.
Yeh there was a small hole. I plugged it, and the wheel well FILLED UP, it was letting it empty, not the cause. I believe the cause is water is coming in behind the rear tail lights (the water that gathers in the boot lid gutter).
That is what was in it and died.. I can get another, and hope it doesn't die again.... I got in and got the old pump out to take with me, and double check it is broken.
Discovered my pump hadn't died. It just choked.
Had it out, and was testing it on a battery, tapped it a couple times, whatever got caught in it came free, and all is good again.
It choked cos when it was installed the teabag off the bottom of the standard pump wasn't put on it, so put that on, and now should be all happy and good.
Will put it back in tonight - *fingers crossed*
Next to sort out the water coming in from behind my lights...
good to hear that about the pump. Just keep an eye on it though.
Yeah, shall do. I don't even think that pump had been in there that long or many km's... But at least I can keep an eye on it, and it is a fixable problem.
Perhaps.
But this is a nice Walbro one, and it seems to work, I've put the filter on the bottom and will give it a shot when get home.. *fingers crossed*
If any issues re-occur, I know where to ask. Why the change in pump Kat? I may be willing to get it as a spare just in case depending on the price.
I'll take all the inside panels out of the boot, and take a look and see if can see where water is coming in by pouring some water into the boot sill. I think the water is running behind the headlights then getting into the boot from there, cos the wood in the back was wet, as was the bottom edges of the side wall carpets near the lights.
I can live with the moisture in the rear lights if I must, but not a wheel well fulla water!
yeah stuff having it full of water. Moisture will be unavoidable though given the age of the plastics and guaranteed hairline cracks somewhere...
Kat is changing her fuel setup as her power/boost requirements exceed the flow capacity of her current setup lol....she should be exceeding 400awkw, so it would seem her pump just can't cope :rolleyes:
hopefully the only issue you have with your pump was that it got plugged up.....if the pump fails though while under high revs/full throttle, be prepared to do some nasty damage to the engine...but it's unlikely if the pump itself is fine.
How much would u want for the old one?
Mine was an in tank walbro - gonna put it back and see if works any way, so fingers crossed now that has been cleaned out, flushed, and a filter put on!
Yep Troy is right, it's not cutting it anymore so it's going to make way for 2 in tank Walbros.
Probably the easiest way to find the leak is to strip all the lining out of the boot and jump inside with a torch while your mum* runs water from a garden hose over the closed boot lid. You can usually see where it's coming in.
* Important note - your mates are no good for this job, they'll leave you in there for sure :D
Oh, and I think I have a spare GTR pump somewhere if you are looking to upgrade sometime.
I can just pour the water myself into the edge around the boot. it definately comes in somewhere behind the tail lights, but can't see how, the lights are all properly tar'd in.
However just noticed the rear panel of the car (sides) are filled with water from recently.. but that was cos I plugged the hole that I thought the water was coming in from - when inface it was coming out of.
I've put the old pump back now that is working, it pumps, but was still not able to start the car. Does it need some sort of priming? it fired over a couple times, but only for a single beat then didn't work... Getting frustrated now, cos the pump is definately working...
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
