hey mate,
how much are u after for these
Set of 4 x white 17 x 8” and 17 x 9” 35mm offset jap racing wheels with worn Dunlop D02 on them.
thanks
I wanted to clean them up first to see how they look and possible get them re-sprayed and or re coloured. Currently they are white. I surpose $600? I was going to spend $200 on them and restore them back to new and look for more. If you are local come take a look if you are keen.
  • Replies 57
Depsits taken on, the following.
Seat, suspension, Headlights and blinkers, Nismo rear pods, Rear calipers and rotars, bonnet
I'll take the adjustable camber arms champ. Could you please PM your number so i can contact you as i can't PM. Thanks.
PM sent
I'll take the GTR front brake calipers and pads if you'll post to SA? PM me with an email adress, details and i can make a deposit.
PM sent
I have the following R32 GTS-T specific parts
Fully adjustable suspension. Height, dampener and cones with 3 pairs of springs 4,6 & 8 Kg's 500km old $500
am interested in the hsd coilovers......please pm me as i dont have 10 posts yet
hey mate can send me your number through Pm mate
also mate how loud was the exhaust? any cracks?
Sorry zorst SOLD
OK the following stuff is SOLD.
Rear calipers
Rear Rotors
Bonnet
Seat
Lights and blinkers
SUSPENSION ADJ COIL OVERS (PLEASE NO MORE PM's!)
Gear Box
Tail shaft
Rear pods
Exhaust
Turbo
Diff (all of it)
18 x 11 Wheels
18 x 9.5 wheels
DS2500 Ferodo pads
I have a deposit on the following which will be picked up tomorrow.
Front Adj Camber arms. Being posted tomorrow
Front calipers and pads
Rear Brace
Oil cooler kit
Set of white 17 x 8 and 17 x 9 wheels
The GTR brake conversion kit has also been removed
Thanks all, I now have my garage back!
hey mate keen on the coil overs and the steering rack can u pm me ur details so i can organise some postage and payment?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
