hey mate,
how much are u after for these
Set of 4 x white 17 x 8” and 17 x 9” 35mm offset jap racing wheels with worn Dunlop D02 on them.
thanks
I wanted to clean them up first to see how they look and possible get them re-sprayed and or re coloured. Currently they are white. I surpose $600? I was going to spend $200 on them and restore them back to new and look for more. If you are local come take a look if you are keen.
  • Replies 57
Depsits taken on, the following.
Seat, suspension, Headlights and blinkers, Nismo rear pods, Rear calipers and rotars, bonnet
I'll take the adjustable camber arms champ. Could you please PM your number so i can contact you as i can't PM. Thanks.
PM sent
I'll take the GTR front brake calipers and pads if you'll post to SA? PM me with an email adress, details and i can make a deposit.
PM sent
I have the following R32 GTS-T specific parts
Fully adjustable suspension. Height, dampener and cones with 3 pairs of springs 4,6 & 8 Kg's 500km old $500
am interested in the hsd coilovers......please pm me as i dont have 10 posts yet
hey mate can send me your number through Pm mate
also mate how loud was the exhaust? any cracks?
Sorry zorst SOLD
OK the following stuff is SOLD.
Rear calipers
Rear Rotors
Bonnet
Seat
Lights and blinkers
SUSPENSION ADJ COIL OVERS (PLEASE NO MORE PM's!)
Gear Box
Tail shaft
Rear pods
Exhaust
Turbo
Diff (all of it)
18 x 11 Wheels
18 x 9.5 wheels
DS2500 Ferodo pads
I have a deposit on the following which will be picked up tomorrow.
Front Adj Camber arms. Being posted tomorrow
Front calipers and pads
Rear Brace
Oil cooler kit
Set of white 17 x 8 and 17 x 9 wheels
The GTR brake conversion kit has also been removed
Thanks all, I now have my garage back!
hey mate keen on the coil overs and the steering rack can u pm me ur details so i can organise some postage and payment?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
