Hey all
Alot of time and cash went into building this animal of a motor, The look on the few people's faces who have seen what this engine can do = pricless !!! Will not disapoint !!!
I have this advertised in my group sale but thought it needed to be put on its own.
Happy to answer any questions so dont hesitate to ask.
ITEM : BUILT RB24
CONDITION : NEAR NEW
INFO :
ENGINE HAS JUST BEEN RUN IN WITH A HKS 25/30 AND IS A ANIMAL!! ( Run in was done for 600KM @ 5PSI and no more then 4000RPM ) Once run in was done 20PSI and 8000RPM was set where it MADE 270RWKW & 840NM TORQUE WITH A HKS 25/30 !!!! DYNO PRINTOUT PROVEN. Engine will handle 9500RPM and over 600HP no worries.
BOTTOM END IS BRAND NEW
SPEEDLAB CUSTOM RB24 ( CUSTOM MACHINED R34 GTR CRANK )
GRUB SCREWED CRANK
LINISHED CRANK
EAGLE RODS
TOMEI PISTONS
ARP RACE SERIES STUDS
TOMEI RINGS
PISTONS HAVE BEEN TEFLON COATED
FRESH LINE BORE AND HONE
ACL RACE SERIES MAIN AND ROD BEARINGS
CUSTOM SUMP BAFFLES WITH TRAP DOORS
CUSTOM 9L SUMP
N1 OIL PUMP
N1 WATER PUMP
CUSTOM HKS 1.2MM HEAD GASKET
THIS BOTTOM END HAS BEEN MADE TO STAND BIG HP AND BIG RPM. ONLY TOP QUALITY PARTS FROM JAPAN, USED AND THE BEST MACHINING HAS BEEN DONE.
THIS BOTTOM END HAS COST ME BIG $$$
ENGINE ( HEAD )
FULL RACE PORTING
JUN 272 – 10.8mm LIFT ( BIG ) INLET AND EXHAUST CAMS
JJR ADJUSTABLE CAM GEARS
TOMEI SPRINGS
TOMEI BUCKETS
GREDDY TIMING BELT
CUSTOM OIL DRAIN MACHINED FROM THE BACK OF THE HEAD TO SUMP.
CUSTOM PAINTED ENGINE COVERS
THIS HEAD HAS HAD OVER $7K SPENT ON IT IN MACHINING AND PARTS FROM JAPAN.
THIS WOULD MAKE A GREAT STREET ENGINE OR TRACK ENGINE.
CONTACT : PM ME
PICTURES : HAPPY TO SEND OR COME LOOK AT IT.
PRICE : $6800 ONO
https://www.sau.com.au/forums/topic/344466-built-rb24/
bit rich? i built my motor n it isnt even a rb24.. n it cost over this amount.. And this thing would be a fkn weapon!! Big thumbs up for being a bit original with it dude.. Shame ur sellin up. Good luck with sale.
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5566454
Just a bit rich for me personally mate, ie, I don't like my 32 that much :rofl2:
Free bumpage OP :rofl2:
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5570348
PICS
Also have a the dyno report which shows 270RWKW @ 1.7BAR and 840NM TORQUE with a HKS 25/30 !!
Sorry for the quality were taken in darkish warehouse using my phone.
Engine is sealed and wrapped , Just un rapped it for these pics.
Cheers
Edited by stylz7
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5574592
Motor is still up for sale guys
I can sell it on its own as a long motor or can sell it as a package which includes the following
RB24 long motor
custom front mount and piping to suit gtr plenum in 32 gtst ( would be hard to make the piping suit any application )
RB20 gear box in good condition
Autronic SM4 ecu with custom loom and sensors to suit this setup
HKS fuel rail and 580cc Injectors
HKS 25/30 turbo
Motor on its own $6500 ONO without the above parts
or motor with above parts as a package $10500
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5585046
Hi, cant see myself buying the engine as I am trying to sell all my Toney RB24 parts myseld. But interested to see a dyno sheet and difference between std RB20s with 2530s. That is certainly an impressive figure for a HKS 2530...but whatever the number, the shape of the curve would be interesting. Perhaps it will change my mind :)
Free Bump for a cool engine!
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5585061
$8000 for the lot guys !!!! COMPLETE PACKAGE
BUILT RB24
HKS 25/30
FULL PORTED HEAD
BIG CAMS
9L SUMP
AUTRONIC SM4
CUSTOM LOOM
RB20 GEAR BOX AND TAIL SHAFT
HKS TWIN PLATE CLUTCH
HEAPS MORE
$8K THE LOT !! YOU DO THE MATH AND SEE THAT THIS IS BY FAR A BARGAIN !!!
https://www.sau.com.au/forums/topic/344466-built-rb24/#findComment-5599518
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
