The annual SAU Dyno Day - Register your interest NOW
Don't worry Lach I've already tee'd Shaun up to give us an 80rwkw bonus as home court advantage :D Even if Steve still pips up we'll jump back on thre dyno and add a bit more X factor:D
I can see it now...
Freebaggin 1st run - 280rwkw
Grepin 1st run - 290rwkw
Whatsisname 1st run - 290rwkw
Steve 1st run - 340rwkw
Freebaggin & whatsisname whisper to Shaun.......
Freebaggin 2nd run - 365rwkw - nice improvement there mate!
Whatsisname 2nd run - 365rwkw - oh look at that neck & neck!
Equal first winners :D
  • Replies 228
Excellent mate, a bit of brains and thoroughness makes the difference eh.
absolutely
whatsisname, if you really want to beat me all you need to do is turn my boost down when I am not looking, then remove my hand controller - dont even have to bodge figures - or, you could just block off my CAI intake pipe during the run:) that should do it.
Naa bodging figures is easiest :D
But in all seriousness, it's really good to see your package making the numbers it's capable of. I knew it had plently in it back when you showed me the previous dyno print out, it was rich as hell! Go the RB25DET's
Looking forward to it for sure, but What's, your right, gotta be some favouratism thrown in there.....can't have these bloody last minute ring-ins "winning" :thumbdwn:
thanks Matt, I just had a look at the previous dyno on you thread, and the bottom end and midrange looks alot different, certainly feels different.
also, to appease one of our mods:):(
***Please Note****
Dyno Day is on the 6th of March.
T-man, you still good for bringing the BBQ?
Enrico, you still good with the TV?
Also, does anyone have esky space for some sausages? or perhaps I can just put them in the sun to pre-cook?:D
Cheeky I understand that there is more to life then cars and I never stated otherwise but it is comon to have problems with relationships when cars are involved thats all. And if you wanted people to mind there own buisness on the forum you should hold back information about it then. Not trying to cause trouble but I hope you understand I do it sucks when things go down hill but please if you bring up your relationship in a public forum excpect things to be said, that is all.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
