lot of people put R34 coilovers in and find that the back end is a bit soft - because of all the extra weight over the rear suspension that the wagon has over a sedan/coupe.
mine has got GT-R coilovers in it, but with higher spring rates in the back and i reckon it handles and rides pretty nice. i can find out toinght what the spring rates are for you, but from memory they are 12kg.
I currently run 12kg front and 10kg rear (have done so for over 2 years) ... but downsizing to 10kg front and 8kg rear, as I'm growing tired of Adelaide "pot hole" roads.
So I would recommend 10kg front and 8kg rear.
Ok great thanks Ruby! Im looking at a set of coilovers at the moment, which have 9kg & 7kg! So thats fairly close, what do you think? Close enough or should i look for a set 1kg firmer?
It might take a bit of reading, but have a look through this thread: http://www.skylinesaustralia.com/forums/St...ion-t53079.html
SydneyKid did a LOT of work early in the piece to find out heaps about the suspension in the Stagea and used to offer a kit that he'd developed (he's a suspension engineer) for Stageas, Skylines, S-chassis cars (S13/S14/S15), and quite a few other cars.
Well that was a long and sometimes painful read, some interesting stuff in there too! While SK did obviously put in alot of effort in the early days of the stagea being in Aus, and much respect for the effort & shaing the info, i feel (with no disrespect intended) that he is rather conservative with his settings! 3kg springs really? I have king springs & the whiteline bars in the car at the moment and its waaaaaay tooooo soft & even the bars could do with the next size up X & XX, im not happy with the std setup at all! Well i think i will use that as a base line guide, but do it my own way & post the results when it all comes together (good or bad)!
Cheers for your input guys, i'll keep ya posted on my progress! (eventually we can compile an abstract or a definative guide to stagea suspension modding)! (rather than read a million pages)
When Sydneykid did the kits, he had the springs made esp to his spec's. They are all sold now and it was not worth him getting 10 sets (min) order done. He advised me the closest other springs available were the King springs.
I ended up fitting these with a set of his Bilstiens. My opinion the springs are more than heavy enough. They are around 25% heavy than stock at around 4kg. Springs are R33 GTR front, R32 GTR rears in Low spec. Do not use super low spec.
You mentioned you have kings already, but what shocks have you got?
If they are stock than I would say that is why you think the kings are too soft. Any spring8kg or higher on the street to stiff for our crappy roads.
FYI,
I found 8kg front with 6kg rear to be a good mix, thats what is in Smokeys car as it used to be mine. It was running R33 GTR Greddy Coilovers, these come with linear front springs and progressive rears, I swapped the rears out for 6kg linear eibach springs.
Eibach springs are probably about the best you can get if you are after springs as they have springs in almost every weight, diameter, length and they are awesome quality too. Also they are not that much probably pay around $4-500 for a set all around I reckon.
hey mate i have isc coilovers i brought around a year and a half ago which came with 12kg fronts and 10kgs rear i found it just to stiff so i just recently brought 8kg front 6kg rear springs and so far so good alot softer than before . car still handles great
I have tein s-tech springs specifically for WGNC34. They are rated at 3.6kg front and 3.8kg rear. They arent stupid low either. I have a R33 GTR swaybar to fit on the front and 24mm whiteline solid swaybar coming soon. Good for most road conditions. SK Bilsteins with adjustable circlip would be ideal. Track cars run a stiffer setup.
Edited by dirtyRS4
I just bought HKS coilovers, with a few sets of springs 5->9kgs, so i will play around and see how its goes! (i like to drive pretty hard through the hills, wanted a gtr, but needed a wagon, so.... super stagea it is)
As long as you have upgraded the sway bars to control the roll then the spring/shock combo can mostly spend its time controlling vertical changes.
From here it comes down to personal choice so if you weren't happy with the firmness then going up in spring rates is a fair thing.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
