lot of people put R34 coilovers in and find that the back end is a bit soft - because of all the extra weight over the rear suspension that the wagon has over a sedan/coupe.
mine has got GT-R coilovers in it, but with higher spring rates in the back and i reckon it handles and rides pretty nice. i can find out toinght what the spring rates are for you, but from memory they are 12kg.
I currently run 12kg front and 10kg rear (have done so for over 2 years) ... but downsizing to 10kg front and 8kg rear, as I'm growing tired of Adelaide "pot hole" roads.
So I would recommend 10kg front and 8kg rear.
Ok great thanks Ruby! Im looking at a set of coilovers at the moment, which have 9kg & 7kg! So thats fairly close, what do you think? Close enough or should i look for a set 1kg firmer?
It might take a bit of reading, but have a look through this thread: http://www.skylinesaustralia.com/forums/St...ion-t53079.html
SydneyKid did a LOT of work early in the piece to find out heaps about the suspension in the Stagea and used to offer a kit that he'd developed (he's a suspension engineer) for Stageas, Skylines, S-chassis cars (S13/S14/S15), and quite a few other cars.
Well that was a long and sometimes painful read, some interesting stuff in there too! While SK did obviously put in alot of effort in the early days of the stagea being in Aus, and much respect for the effort & shaing the info, i feel (with no disrespect intended) that he is rather conservative with his settings! 3kg springs really? I have king springs & the whiteline bars in the car at the moment and its waaaaaay tooooo soft & even the bars could do with the next size up X & XX, im not happy with the std setup at all! Well i think i will use that as a base line guide, but do it my own way & post the results when it all comes together (good or bad)!
Cheers for your input guys, i'll keep ya posted on my progress! (eventually we can compile an abstract or a definative guide to stagea suspension modding)! (rather than read a million pages)
When Sydneykid did the kits, he had the springs made esp to his spec's. They are all sold now and it was not worth him getting 10 sets (min) order done. He advised me the closest other springs available were the King springs.
I ended up fitting these with a set of his Bilstiens. My opinion the springs are more than heavy enough. They are around 25% heavy than stock at around 4kg. Springs are R33 GTR front, R32 GTR rears in Low spec. Do not use super low spec.
You mentioned you have kings already, but what shocks have you got?
If they are stock than I would say that is why you think the kings are too soft. Any spring8kg or higher on the street to stiff for our crappy roads.
FYI,
I found 8kg front with 6kg rear to be a good mix, thats what is in Smokeys car as it used to be mine. It was running R33 GTR Greddy Coilovers, these come with linear front springs and progressive rears, I swapped the rears out for 6kg linear eibach springs.
Eibach springs are probably about the best you can get if you are after springs as they have springs in almost every weight, diameter, length and they are awesome quality too. Also they are not that much probably pay around $4-500 for a set all around I reckon.
hey mate i have isc coilovers i brought around a year and a half ago which came with 12kg fronts and 10kgs rear i found it just to stiff so i just recently brought 8kg front 6kg rear springs and so far so good alot softer than before . car still handles great
I have tein s-tech springs specifically for WGNC34. They are rated at 3.6kg front and 3.8kg rear. They arent stupid low either. I have a R33 GTR swaybar to fit on the front and 24mm whiteline solid swaybar coming soon. Good for most road conditions. SK Bilsteins with adjustable circlip would be ideal. Track cars run a stiffer setup.
Edited by dirtyRS4
I just bought HKS coilovers, with a few sets of springs 5->9kgs, so i will play around and see how its goes! (i like to drive pretty hard through the hills, wanted a gtr, but needed a wagon, so.... super stagea it is)
As long as you have upgraded the sway bars to control the roll then the spring/shock combo can mostly spend its time controlling vertical changes.
From here it comes down to personal choice so if you weren't happy with the firmness then going up in spring rates is a fair thing.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
