about 12 weeks ago i posted up my new ride, it was in japan at that time and now she is in my garage...
here are some pics of her.
all pics taken with a nikon coolpix 880 with 8 second exposure, 200 ISO.
front lip is currently off the car until it gets registered..personally i think it looks pretty crap from the front....
  • Replies 58
Originally posted by initialD
ssshhhweeet car,
i got a cool pix 775 how do i adjust exposure and iso???
me too.. how do i make flash come on in day? i so dont know how to use it. all i do is point and click.
ummm... all i can think of when looking at that r34 is ..... DROOOOOOOOOOOL!:wassup:
zsky: can't say price just yet :)
thanks for the comments,
dont know about the programmability of the 775 to be honest. your better off consulting your manual!?
as for forcing flash, there is a flash button on the back of the camera i presume (on mine there is) and you select the lightning bolt. in auto mode the camera will most likely not use it, when the lightning bolt is up then it forces a flash...useful for "fill flashing" i gather?
Now for some silly Questions, as I am to tired to search for the answers.
4WD?
TwinTurbo?
Factory Color?
After Market Mods?
Factory Extras?
And could you please PM me, some info, Who you got it through, Cost, please. I will keep the details to myself.
The R34 is the reason I am not going to spend much on my R33 as far as Mods go.
So I can save up sell mine and get an R34.
And lastly, could you send me some more pics, as the quality is awsome, size of file dont matter.
[email protected]
Please with cherry on top :)
holy motha....
that looks sooooooooooooooooo good.....
i've promised to myself that i wouldn't spend any money on bodykits and stuff for my r, coz i've kinda been there done that with my gtst and when i sold the car i didn't get anything back it was just pure waste of money... BUT cars like this (and i must admit there aren't that many ... congrat mate!@!!!!!) make me think may be i should put some effort to make my r look tad tougher...
god damn it! u know how hard it is to turn a maori red! LET ALONE GREEN!!! (envy... not really my colour :))
well... thats it... as soon as i can get insurance (ie. over 25) im god damn getting one! no ifs or butts about it... by the time i am able to get a decent rating the prices should have dropped a fair bit anyway.
Nice pics Franky :) Look forward to cruising with you soon ! btw. do you know the other guy who owns a yellow 34 round ashfield way ? You guys could almost be mistaken for twins :D Glad the colour turned out to be ok, musta just been the photo's taken in japan that looked whacked
It's obvious why the Aust. car manufacturers are trying to stop grey imports!
R34GTT vs Monaro
Half the price, looks nicer, goes harder, handles better, climate control ......
And that's for an unmodified GTT - spend a few grand on mods for each car and then compare! :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
