hi all. sorry to bother ppl with this.. but my car has been havent these problems that happen and stop, but always happen when i drive for 10 minutes.. and i feel flat spots.. this all happened when my afm got wet, but for years now, ive seen a little bit of fuel out of my exhaust. does it, then stops, then over time again...
i disconnected my o2 sensor, and thats the only way i can really drive without it reving off and stoping.. but i do need to go easy and slow the revs down when i stop so i dont stall.. its about 300rpm low in idle with the o2 disconnected... bought a new one, connected. same issues.. and now, the only way i can start is to disconnected the o2 sensor, or disconnected the ecu or battery and start the car.. i nkow the ecu has its own afm setting for air, just ot start the car.. so this must be why i can start it, and its ok, drive and the issue can happen, worse times then others.. and it did happen whn the afm got wet and i dryed it out.. it was in safe mode for 2 days, reed out to 25000rpm, when the afm dryed, it orked, but this issues..
sory for the long story, wante3d to get it out, so people have a idea im on the rigt track, i use ecu talk as well..o2 is like 0.8 in idle when this happends.
can some one lend me one for a day, i might buy it if its for sale. i just want to make sure before i buy things.. thanx to anyone that can help me out..
https://www.sau.com.au/forums/topic/344714-borrow-a-r33-gtst-s2-afm/
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
