Turbo spec's Apexi AX53B70 P25
Guest darrinspencer
Does anyone have the spec's on a Apexi turbo model AX53B70 P25
Are these ball bearing?
What power is expected if fitted to a RB25det
Thanks.
There was a thread recently that showed a chart comparsion between most turbo's, but I can not find it.
Can someone help.
https://www.sau.com.au/forums/topic/34483-turbo-specs-apexi-ax53b70-p25/
Thanks.
Can someone help.
The specs for this turbo are:
Ball Bearing, 380ps rating
Compressor Wheel :
Trim - 57
Major Diam - 70mm
Entrance Diam - 53mm
Turbine Wheel :
Trim - 82
Major Diam - 53mm
Exit Diam - 48mm
Its available with a T3 flange.
