i have twin hks 2530 turbos on a gtr with gold looking actuators....
the problemb we are having is boost spikes and holding steady boost..
it can hold about 16psi but no more as the boost jumps all over the place....
but sometimes even it spikes if i leave the boost at one setting..
could my old actuators be getting sad......
if i upgrade to the hks silver 1.0bar actuators can they hold higher boost..
i am running a new blitz id 3 controller in manual mode set to 52 boost ratio and 20 gain.. (16psi).i also mounted the blitz soleniod under the pod filters so the hoses are nice and short for better response..
cheers...
https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/
Hi Mark we always run the wastegate spring rate as close to the boost level as we can. This means the boost controller, whatever type, only has to regulate a small amount. Plus the higher spring rate eliminates any chance of premature wastegate opening.
I am not familiar with the Blitz boost controller, so I can't help there.
Mark,
That's a great boost controller you have there, one of the best on the market. Gain doesn't seem to be too high, but have you tried setting it on zero and seeing if that corrects the boost spike?
When setting up a boost controller, you should always put gain to zero, and set the solenoid duty until you reach the desired boost level being held at peak, and then slowly turn up the gain to bring up the response at much as possible without spiking (too much)...
As SK said, the best method of boost control is buy a wastegate actuator with the correct spring rate to open at your desired boost level, but that eliminates the ability to turn the boost down for wet weather/valet parkers/friends/etc...
Good luck!
Mark,
Good luck!
thanks, i might try to adjust the threaded rods on the actuators a bit to load up the spings a bit more..
thanks guys...
yes the silver ones or 1 bar spring i believe...correct me if i am wrong..
my ones are gold but have the adjustable rod....
i have just adjusted the rod a few turns more to preload the wastegates a bit more...
about to try it out after dinner...
another mod i have just fitted a 62deg nismo thermostat to help cooling....how helps a bit...
cheers..
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
