Hi all, I just purchased the Blatz connect cable and programs to plug my r33 into my laptop. I havn't recived it yet but i was just wondering if any had used this before and if i could do any damage to the ECU because i'm just learning and really have no experience with using this system. From what i have seen it looks like a great tool to have to find and fix faults.
https://www.sau.com.au/forums/topic/345473-nissan-connect-cable/
as above. you can't do any damage as you can't actually change any settings on the ecu. some programs will allow you to minorly adjust the timing, etc for diagnostic tests, however the moment you shut down the program it goes back to stock.
with a stock ecu you can't adjust the timing permanently at all. the moment you close down the program or unplug the laptop the ecu goes back to the stock settings. some consult programs don't even allow you to change the timing at all.
if you are getting pinging then it will either be from the car leaning out or the timing being too advanced from CAS adjustment (nothing to do with consult)
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
