actually 20 deg is the 5th mark from the left. the marks from the left are, 0 5 10 15 20 25 30. ignore any reading you get in consult at idle and go off the timing light.
which throttle body and TPS are you running? are you sure your unplugging the correct TPS plug?
the 4th mark from the left. on conzult my timing sits on 15 degrees when at idle.
how do i get to base idle mode using my consult cable?
4th mark is 15 degrees. as qwk32 said (and i meant to say), the 5th mark is 20 degrees, 4th mark is only 15 degrees, so your timing is correct as it is at the 4th mark which is 15 degrees and the consult is showing 15 degrees.
yeah my bad, can't count, LOL (had the workshop manual open and all, LOL)
sorry, i meant the 5th mark. i cant go any lower than the fifth mark with the tps unplugged.
also when idling normally with the tps in, i can set it to 15 degrees easily and the car runs nicely
when i pull the tps plug out it runs like crap and i cant set it any lower than 20
i cant be pulling out the wrong plug? probably am;
heres a pic of the one im pulling out. this is an rb25neo out of a stagea
just double check that colour of the wires of the plug match the colour of the wires of the plug on the tps, since both it and the plug underneath send wires off in the same direction.
the two plugs at the top both go to the tps.
sorry i should have mentioned, the bottom one (grey one) also goes to the TPS but it is a Throttle On/Off switch and is associated with an auto. what ecu are you running do you know? and auto or a manual one?
the black plug is the variable TPS signal you unplug when setting timing.
ok so one if those plugs is for the tps and the other is for the throttle valve switch because this engine was from a auto stagea
do i pull out both plugs?
as above mate, you posted as i was replying. you don't unplug the bottom plug to set the timing. if your running the auto ecu, which isn't a problem, just make sure the bottom plug is plugged in incase the ecu is looking for that signal to help with idle time controls.
Edited by QWK32
ive been running an auto rb25neo stagea ecu; when warmed up and at idle timing sits at 15 degrees on the conzult software
when i put the car into base idle mode and try to adjust the timing i cant adjust it any lower than 20 degrees and it idles really rough.
i just tried a r34 manual rb25neo ecu; when warmed up and at idle timing sits at 5 degrees???? on the conzult software
and when i put the car in base idle mode it idles fine and am able to adjust the timing across the whole range
what options do i have?
problem solved.
used another timing light to confirm my readings. now its set to 15 degrees
and the car drives and runs fine
only problem is it wont start unless i remove the cas and turn it manually.
when its warm it starts without a problem
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
