  • Replies 50
Thanks for the luck Stuart :D
It all comes down to "show me the money" with what we will end up with.
There has been so much going on since Homebush, that it changes many times each day.
Alot of AWD's are faster in 2WD.........and that may mean allowing the Motec or whatever switching to FWD or RWD at various points on a track, depending on the circuit of course.
In Prod cars, alot of teams think FWD is faster in there AWD's.
Well lets hope we are both right , as we just acquired an ex SBR AU.
This year will be a bit quite - hope to catch up with you in the AU or the 33 thru the year.
At the moment Karen and I will be doing mixed events in both cars.
Cheers
oooooh more details on the ex SBR AU Stu?
Hi Evil
Chasis no 4 was Blue, now Black.
Going for a play Monday 31st, Tuesday 1st coming - planning on a fairly quiet set up year, playing with tyres, and stuff - November will see a 5999cc stroker to hopefully go and play in 2012
Cheers
Hi evil , First test at wakefield went ok ,only got about 21 lap myself all day , had some small issues, diff oil leak and a lazy shock - but ended up with a PB for car and self.
Less than a second off record, some decent tyres and a little bit of sorting - totally looking forward to some time in the car
Cheers
This is the record on their website
V8 Supercars
Driver: Steve Owen
Holden VZ 6/04/2008 59.0391
I'm pretty sure their website is out of date. They've run quicker than that.
59.03 is the record.
Qualifying times never count for records, as it must be done during the race.
I don't think Stuart would have done sub 60's on his first go. I am guessing 63's?
Ahh ok, makes sense.
Then again i doubt Stuart was racing?
Anyway 58.4 for a qualifier and 59 flat racing, cool.
The last 6 laps of the day, times are
1.02.894
1.00.686
1.00.072
1.00.032
1.00.134
1.07.260 (cool down)
Best Minimum Rolling in that sesion was a 59.871 (point to point not beacon to beacon)
Motec Data @ 4.10.52PM 1/2/2011 Wakefield Park
Hi Duncan
Heres a picture.
No - not racing, tyres are 2 years old, had suspension and wheel alignment issue now sorted - can't wait to give the 11 year old car another go
Cheers
Boz we did 63's first outing in the GTR R33 at Wakefield on AO50's - full trim and rego, why would you bother purchasing an old supercar to do the same.
Hi Duncan
Heres a picture.
Cheers
Stuart,
you've got to get new tyres and go out smash the time :)
Good luck.
Stuart,
Good luck.
Thanks Ducan,
Settlilng to car and budget this year, chase a couple of sponsors, and hopefully play next year.
Got a heap of spare tyres with the car, thanks to Terry - gunna use these for settle in period and see if we can use some D11 Dunlops for qualifying times.
Cheers
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
