Hi there,
My car is an R33.
I've looked but I cannot find any info.
I noticed the other day that when I flicked on the air con a red light came up on the right hand side of the dash. It had what looks like heat waves coming off a pipe like figure.
It only comes on when I turn the air con on. When I turn it off it disappears. Is it somethin to worry about? I wondered if it was some kind of exhaust sensor that has been disconnected when I had my 3" put in.
cheers,
Dan
https://www.sau.com.au/forums/topic/345789-red-light-on-dash/
Sounds like the catalytic converter temperature warning light, PowerFC use it to indiciate engine knocking
Oh ok, would make sense because I took out the cat... being from NZ.
power fc uses the check engine light to indicate knock by flashing it several times in a short space of time
if its the cat convertor overheat warning then there may be a wiring issue or maybe it was just unplugged when something was done/replaced
The light will come steady on and maybe flick off for a bit after a while, and then turn on again. I have a Z32 computer installed not a powerfc.
Yeah that's fine was just correcting the previous post.
That's a bit strange. The sensor should bring up a warning (that red light) when excessive temperature is noted in the cat. Sometimes this happens with a stock exhaust when the car dumps fuel into the engine at higher then normal boost levels. But since yours has a 3 inch exhaust I wouldn't think so
Sounds more like a wiring problem, or perhaps the sensor is old and as the wires heat up it's creating to much resistance, but again that doesn't explain why it's only doing it when you turn the air con on. Unless your z32 ecu is throwing to much fuel in when the air con is on, perhaps putting it into a rich and retard mode, I'm not sure.
Does the car drive ok when the ac is on and it does this? Maybe just check the sensor and wiring under the car just as a start. But it doesn't sound like anything to be concerned about
Hey thanks for the reply.
I will be seeing my tuner this weekend for other reasons, but I can check it out with him to see if it is the result of his tune. The car drove fine when i had it on A/C but I never really left it on for a long period once I had noticed it.
I don't even have a cat anymore so I would say that is nothing important also. It is just weird with the air con turning.
cheers,
Dan
probably just a wiring fault then. Might just be earthing the wire for the cat sensor when the AC compressor is cutting in and out or something. Just check to see what they did to the sensor when they replaced your exhaust
  • 3 weeks later...
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
