I'll need to check measurements of it tonight for postage quote, hopefully its under 105cm long , otherwise weekend pickup would be fine with me, located at Blue Haven fuel would most probably be cheaper than delivery Im guessin from your area.
cheers mate, its not so much the cost as it is the time as i might be working 10 hour shifts all weekend :unsure:
I know how that feels, I'll check the measurement and get a delivery quote for you...
Sorry to be a pain in the butt, can I get a pic of the exhaust flange please?
Thats not being a pain at all, I'll send you a pic of the flange, alternatively you can have a search around for a secondhand HKS dump that matches, they come up occasionally.
I didnt use the HKS dump I got a custom bellmouth style dump made.
braided lines sold pending payment
shoft shifter sold pending payment
cam covers sold pending payment
Std SMIC sold sent received
r34 turbo and lines sold sent received
weekend bump, fair few enquiries for the HKS turbo, but its still here...
seriously its a perfect match for a rb25... power, response and sounds awesome... fits std manifold...
  • 3 weeks later...
This is whats left guys, open to offers...
Pink labelled r33 Series 2 AFM, replaced due to upgrade - $90
r33 Series 2 Fuel pump, replaced due to upgrade - $70
r33 Series 2 boost solenoid - $40
2x -12 threaded weld on fittings - 2 sets one steel one alloy - $20 per set unused
2x -12 braided line fittings to fit rb25 cam covers - bought from Tuffrx3 on these forums - $40 unused
2x 1m lengths of rubber hose 3-4mm, unused - $7 each
r33 series 2 std turbo, blown front bearing, good for hiflow comes with oil and water lines and elbow - $60
2 silicon and 1 rubber hose joiners, used one from std throttle body the other two std intercooler pipe size $4 each
rb25 series 2 std intake manifold and top and bottom, removed for upgrade - $80
  • 2 months later...
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
