Hey All,
This was suppose to be a project car, with my uncle, but 1. I'm broke, 2. he bought himself an old VL Group A and cbf with this car now. You guys also may know of this 1993 GTS-t :action-smiley-069:
There is no structural damage at all, just all cosmetic, the car will also some with another driver's door, but in white.
Car still starts, still drives straight. Great for project base or drifter or a track s1ut or even a road car. Not on REVs, will supply VIN & Engine number on request.
Most of the panel beating has been carried out, but we got lazy and never finished it.
Yes car is missing headlights.
Make: R33 Skyline, Series I
Year: October, 1993
KMs: 116xxx
Mods: Tein Coilovers, Stainless turbo back exhaust, Yumcha Spec 18" Rims
Price: $4000 ono
Contact: 0412 311 222, please SMS if no answer.
Photos:
If this was in Vic i would be interested, does it run and idle smoothley? Does it get started oftern?
Not often, but it was started on the weekend and moved to the road. Idles great, I can post up a video on the weekend.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
