I have no idea what i'm doing wrong here, installed a fuel pressure gauge in the pipe where it is maked A, should I have done it on the return line where is it marked B? I can get pressure, but only 6psi - trying to sort this before I try start my engine next week
https://www.sau.com.au/forums/topic/345976-fuel-pressure-gauge/
Yeah that's right what you have done, the rail is fed from the rear forward, 6psi there is a prob somewhere.
Have you done a pump upgrade as well?
With ign on, the pump should prime as normal, then the rail should stay pressurized after the pump switches off. Make sure this is happening as it could be a prob with the one way valve if you have done a pump install or something.
No idea what tHe reg is set at. I will wind the adjustor in until it hits the stop tonight and try again. I'm pretty sure the gauge is working as the system never stops priming like it used to with the factory setup, and yep A comes off the fuel pump outlet/filter line. I will pull the pump tonight and check it's not blocked in the tank also, has been a while since she ran. Thanks for the help guys, was very worried there I jphooked up on the wrong line!
stock reg gave me just under 40 psi, but it quickly dropped off after the pump stopped running, couldn't see any leaks in the car, pulled the pump, tried hooking the outlet directly to a hose to pump to a jerry can, it would pump for a few seconds, then die away, so I pulled the pump and the sock but that wasn't really bad either...
Edited by Keeper
when the motor is off? It shouldn't, but most of them do. just means you need to prime the pump a little longer when you start it
if the motor is running and loosing fuel pressure you have some major issue.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
