bought Phillip island track last night and the VW tdi for some FWD love :P felt right at home. flat shift sequential is pretty cool too. just a shame diesel means the gear ratios and revs are all over the place.
I can't see Bathurst on the track list, is it released?
It might be under Mount Panorama, but yes, it is released. Been out for a while now. So much fun!
I'm racing a Tuesday night v8 supercars development league. Fixed setup, great for a level playing field. It follows the fincar series and is run by the same guys. Gets a great turnout of 50+, and good close racing
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7295492
  • 5 weeks later...
Any chance to spectate? Twitch or something?
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7321593
I'm assuming Twitch is some online broadcasting service..? I've never used it before. Would have to test it out beforehand I suppose.
Anything which is too cpu intensive has a good chance of making sim racing utter hell haha.
I'll have a look at it though and get back to you :)
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7321624
  • 1 month later...
  • 6 months later...
Thread bump.
The V8 supercars have had an update ford and holden COTF are out :)
Also starting in the next few weeks a huge V8 premier series. Fully broadcast via V8sonline. You have 3 days of pre qualifying and only the top 80 drivers are accepted and split into a support and main race (both broadcast). Then you have official qualifying and sometimes they do a top 10 shootout. Its no reset buttons and realistic live marshals. So you wreck your car in qually if it doesnt drive back to pits you are out. Its really fun and being hosted does not effect irating or safety.
Link for extra info http://members.iracing.com/jforum/posts/list/3297737.page
Also a few paint jobs i did when I was quiet at home. I now run in a team called Multi 21. Enjoy pics :P Hope to see you out on track.
10313732_10154881672030521_6418043923152
  • Like 1
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7478746
I'm looking forward to doing some enduros with driver swaps, So i'll renew tonight I think
Did the Daytona 24hr with a few mates a couple of weeks back. Pretty hectic. There is a Bathurst 12hr this Sunday.
The driver swap feature is pretty sweet, especially for the Bathurst 1000 haha
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7478938
  • 3 weeks later...
i bought bathurst and the lotus 75 the other day. mt panorama is great! especially in the lotus. the ford v8 supercar (not the updated one) on the other hand... having problems with basic tasks like a) braking in a straight line. b) getting back onto the course when on the grass.
IRL, a car does not rotate 180 on the grass at 15km/h. especially not a v8 supercar
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7491424
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
