  • Replies 48
i was being sarcastic :jester:
can my girlfriend come?
I suppose we shouldn't preclude girlfriends/wives hey ?? As long as they are cool with it and enjoy the entertainment too :D
I'm not too sure about B-Man's intentions here
bean (9:42 PM) :
**** mate - SAU you is a bunch of guys that like to look at guys & chicks - We talk shit about cars all day - lets go perve on some chicks.... Luv it !
[ R O N I N ] (9:43 PM) :
bahahaha
bean (9:43 PM) :
whoops - cars and chicks....... not guys and chicks
OMFG - I don't beleibe I said that !
How embarrasment - Tosh , that's it mate - I'm not ICQing with you any more :rolleyes:
hahahaha
Fark - I'm tired..........it was an honest mistake.
Lets go look at titties guys ! Yeah baby !
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
