  • Replies 48
i was being sarcastic :jester:
can my girlfriend come?
I suppose we shouldn't preclude girlfriends/wives hey ?? As long as they are cool with it and enjoy the entertainment too :D
I'm not too sure about B-Man's intentions here
bean (9:42 PM) :
**** mate - SAU you is a bunch of guys that like to look at guys & chicks - We talk shit about cars all day - lets go perve on some chicks.... Luv it !
[ R O N I N ] (9:43 PM) :
bahahaha
bean (9:43 PM) :
whoops - cars and chicks....... not guys and chicks
OMFG - I don't beleibe I said that !
How embarrasment - Tosh , that's it mate - I'm not ICQing with you any more :rolleyes:
hahahaha
Fark - I'm tired..........it was an honest mistake.
Lets go look at titties guys ! Yeah baby !
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
