Well just had a very disappointing phone conversation with a certain 2nd hand parts Japanese-IMPORTS business, that has absolutely no interest in supporting the products he sells. His words; "As soon as you pay for it and take them home, it's your problem".
A while back, i bought a set of rims, but before being able to fit them to the car, i had an engine fault that required a rebuild. After the car's maiden cruise to Mt Bulla, i had a flat tyre, so i took it to get repaired. Unfortunately there was no fault with the tyre, but a crack in the rim caused the air to escape. There is also no external damage to the rim (apart from the crack).
To be honest i didn't expect this guy to happily replace the wheels, at no cost, but to come to some sort off arrangement where i'd be well looked after (ie: he does not make a profit on the replacement rims).
It just amazes me how people with such a lack of people skills still remain in business. I guess the % off shit that farks up and thus the % of clients he burns, does not out weigh all the other sales that happen to run smoothly.
If you need to know who this guy is shoot me a PM
I am now off to see a wheel repair place, so they could assess whether the rim is repairable.
If the rim is not repairable i will be giving Aaron at Import Monster a call, to replace these rims. Should have used Aaron in the first place!!!
Rant over :banana:
https://www.sau.com.au/forums/topic/346020-buyer-beware/
  • Replies 48
Posted Images
Rant over :banana:
Im really sorry to hear that Al.
Aaron is the greatest man I know for pretty much anything Import Related. New or second hand, it doesnt matter. If he has the contacts you will get it....and at a great price.
Not long ago he hunted down for me a NEW OEM fuel tank for my EMO 6 from Japan......and at half the cost Mitsubishi Aust wanted. The dude is AWESOME
/mancrush
https://www.sau.com.au/forums/topic/346020-buyer-beware/#findComment-5573003
I know what you mean.. when i took my car for a check on a engine fault he told me the problem, left the car with him and when i came back the next day told me it was something else and he still needed $250 even though there was no work done to the car...
Some people... sad world.
https://www.sau.com.au/forums/topic/346020-buyer-beware/#findComment-5573018
Rang up Neway Wheels and was advised that they no longer repair cracks in alloy rims as it may re-crack and cause an accident. I had also been advised by my metal fabricator (when i asked him to weld my spacers to the rims) that welding alloy softens the material.
So looks like i'll be giving Aaron a call. Hopefully he could track down a pair of ragamasters 18x8.5-35, otherwise i'll just buy a new set and use the rears for DECA :banana:
https://www.sau.com.au/forums/topic/346020-buyer-beware/#findComment-5573041
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
